Date/Time: Sat, 18 May 2024 22:26:28 +0000
Compact tool values window doesn't show all values w/futures using Point and Figure study
View Count: 695
[2016-01-24 02:27:26] |
opmetal - Posts: 65 |
When the Point and Figure study is on a futures chart the compact tool values window only shows the "Y" and date columns. Stock charts with the study show all values selected in Chart Settings/Advanced Settings/Display Main Price Graph Values in Values Windows. This happens with every futures symbol I've tried: ES, NQ, TF, YM, 6e, 6j. I have attached 3 screenshots to show the problem. Note that before you made changes to the Point and Figure study in version 1335 this was not an issue. Thanks for looking into this. |
stock_daily_chart_with_PNF_study.png / V - Attached On 2016-01-24 02:26:25 UTC - Size: 25.8 KB - 220 views future_daily_chart_with_no_studies.png / V - Attached On 2016-01-24 02:26:33 UTC - Size: 18.15 KB - 228 views future_daily_chart_with_PNF_study.png / V - Attached On 2016-01-24 02:26:38 UTC - Size: 26.66 KB - 210 views |
[2016-01-24 04:22:40] |
You have disabled Display Name and Value in Chart Values Windows option for the Study Subgraphs to prevent these values from displaying. This is certainly not the default. There have been no changes affecting that option. Refer to this help topic: Http://www.sierrachart.com/index.php?page=doc/helpdetails67.html Also one screenshot was sufficient. Keep in mind we are very busy. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-24 06:22:45
