Date/Time: Sun, 19 May 2024 00:37:34 +0000
TT Fix adapters
View Count: 740
[2016-01-23 18:20:26] |
User0071 - Posts: 2 |
When attempting to test data feed between Sierra Charts TT FIX data service and my TT ladders on X_Traders I am met with the following error on the log Expected "8=FIX.4.4" but received "8=fix.4.2" I spoke to TT about this problems and they replied with 'Adapters speak in FIX42 not FIX44. You will need to speak with Sierra Charts to get a version that is written on FIX42. |
[2016-01-24 02:19:45] |
Sierra Chart does use FIX 4.2 for TT FIX adapters. We need to see the entire Message Log. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-24 02:22:06] |
Make sure you have set the Global Settings >> Data/Trade Service Settings >>Service to "TT FIX". There should definitively not be a problem with this at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
