Date/Time: Sat, 18 May 2024 16:14:14 +0000
chart calculator tool
View Count: 1006
[2016-01-23 00:20:36] |
jivetrader - Posts: 395 |
..would be more helpful if it also showed the number of bars measured. thanks |
[2016-01-24 04:28:24] |
Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DTConfigurationChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
