Date/Time: Sun, 26 May 2024 23:19:42 +0000
issues w price value/crosshair
View Count: 734
[2016-01-22 20:25:51] |
Jim - Posts: 31 |
Hello, I use CSI for my daily and weekly data. on the currency futures when I move the cross hair over a particular daily candle. It skips. For ex in the aussi the crosshairs min move is 100 pips. Thanks for your help. |
[2016-01-22 20:29:58] |
Check the Tick Size setting in Chart >> Chart Settings.
[2016-01-22 20:37:07] |
Jim - Posts: 31 |
In the aussi its set to 0.010000
[2016-01-22 20:50:34] |
Jim - Posts: 31 |
I got it. Added 2 more zeros after the decimal. Thanks for your quick response. Best regards, Jim |
[2016-01-23 08:41:20] |
OK, set that as appropriate along with the Price Display Format. We do not know what they should be since you are using your own data. You can set these permanently through the Global Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
