Date/Time: Sat, 18 May 2024 22:46:01 +0000
Volume for stocks?
View Count: 621
[2016-01-22 16:33:48] |
User455772 - Posts: 22 |
Is there something I need to do to get the volume to work right for stocks? It's like I need a multiplier in there or something.... Thanks! |
[2016-01-22 18:51:13] |
We see you are using Interactive Brokers. Refer to: Interactive Brokers Trading Service: Historical and Real-time Stock/Equities Data Volume Differences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
