Date/Time: Sat, 18 May 2024 14:44:55 +0000
compiler error
View Count: 774
[2016-01-22 16:30:52] |
jivetrader - Posts: 395 |
-- Starting build of Custom Studies Source files: cg_b1.cpp. -- 11:27:38 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\cg_b1.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "C:\SierraChart\Data\cg_b1.dll" C:\SierraChart\ACS_Source\cg_b1.cpp:3:10: error: expected constructor, destructor, or type conversion before '(' token SCDLLInit("CG_b1"); ^ -- End of Build -- 11:27:39 |
[2016-01-22 16:59:05] |
Sierra Chart - Max - Posts: 5618 |
Replace: SCDLLInit("CG_b1");
With: SCDLLName("CG_b1");
Sierra Chart Support Date Time Of Last Edit: 2016-01-22 18:42:28
[2016-01-22 18:06:24] |
-- Starting build of Custom Studies Source files: ehlers_b1.cpp. -- 13:05:50 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\ehlers_b1.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "C:\SierraChart\Data\ehlers_b1.dll" C:\SierraChart\ACS_Source\ehlers_b1.cpp:7:10: error: expected constructor, destructor, or type conversion before '(' token SCDLLInit("ehlers#1"); ^ -- End of Build -- 13:05:51 STUDY CODE: #define WIN32_LEAN_AND_MEAN #include <windows.h> #include <math.h> #include "sierrachart.h" SCDLLInit("ehlers#1"); SCDLLName("ehlers#1") SCSFExport scsf_ehlers(SCStudyInterfaceRef sc) { SCSubgraphRef Ehlers = sc.Subgraph[0]; SCSubgraphRef Mid = sc.Subgraph[1]; if (sc.SetDefaults) { sc.GraphName = "ehlers#1"; sc.StudyDescription = "ehlers#1 >> beta 1<< @ganz"; Ehlers.Name = "ehlers#1"; Ehlers.DrawStyle = DRAWSTYLE_LINE; Ehlers.PrimaryColor = RGB(255,255,0); Ehlers.LineWidth = 2; sc.GraphRegion = 1; sc.ValueFormat = 2; sc.AutoLoop = 1; sc.FreeDLL = 0; return; } float a1, b1, c1, c2, c3; a1 = exp( (-1.414) *3.14159/10); b1 = 2*a1*cos(1.414*(180*3.14159/180)/10); c2 = b1; c3 = (-1)*a1*a1; c1 = 1- c2 - c3; // Ehlers[sc.Index] = c1*(sc.BaseDataIn[SC_LAST][sc.Index] + sc.BaseDataIn[SC_LAST][sc.Index-2] )/2 +c2*Ehlers[sc.Index]+c3*Ehlers[sc.Index]; float al, tr, fi; tr = 360*3.14159/180; fi = 0.707*tr/48; al = (cos(fi) + sin(fi) - 1)/cos(fi); Mid[sc.Index] = (1-al/2)*(1-al/2)*(sc.BaseDataIn[SC_LAST][sc.Index]-2*sc.BaseDataIn[SC_LAST][sc.Index-1]+sc.BaseDataIn[SC_LAST][sc.Index-2])+2*(1-al)*Mid[sc.Index-1] - (1-al)*(1-al)*Mid[sc.Index-2]; Ehlers[sc.Index] = c1*(Mid[sc.Index] +Mid[sc.Index-1] )/2 +c2*Ehlers[sc.Index-1]+c3*Ehlers[sc.Index-2]; } |
[2016-01-22 18:43:30] |
Remove SCDLLInit("ehlers#1");
