Date/Time: Wed, 08 May 2024 15:41:07 +0000
Small bug with saving chart as image
View Count: 1288
[2013-06-26 18:44:34] |
looking_afar - Posts: 17 |
Hi, guys. I have a daily chart of ES# (SC Data Service). So in the chart settings Symbol is set to "ES#" and "Alternate Real-Time Update Synbol" is set to "ES-201306-GLOBEX", so the chart header is "ES#/ES-201306-GLOBEX". When I try to save the chart as an image (Edit > Screen Images > Save chart...) either with header or without I get: Could not save the image file: E:\Program Files\SierraChart\Images\ES#/ES-201306-GLOBEX [R] Daily #1 41451.765.png | 2013-06-26 11:21:34 Could not save the image file: E:\Program Files\SierraChart\Images\ES#/ES-201306-GLOBEX [R] Daily #1 41451.7725.png | 2013-06-26 11:32:24 It looks like SC tries to use a slash in the filename, which is not possible in windows. Maybe you could fix this when you have time. Thanks |
[2013-06-26 19:28:01] |
This will be resolved in the next release. Thank you for pointing it out.
