Date/Time: Sat, 18 May 2024 18:46:36 +0000
New laptop
View Count: 673
[2016-01-22 07:37:36] |
User569811 - Posts: 3 |
Dear All I got a new laptop and I downloaded version 1357 on it but the intraday charts are not appearing. I should have downloaded version 1354? Now should I unistall 1357 and install 1354? Regards Charbel Gebara |
[2016-01-22 08:11:08] |
What Data or Trading service are you using or do you wish to use? See this page for the list: http://www.sierrachart.com/index.php?page=doc/Data.php&CAID=def#Services Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Tell us also one of the symbols you want to get a chart for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-22 08:11:52
