Date/Time: Sat, 18 May 2024 20:20:04 +0000
Synchronise Charts
View Count: 633
[2016-01-21 20:08:58] |
User57072 - Posts: 49 |
After working on some charts, how can i duplicate that on another computer located at my farm ?
[2016-01-21 21:13:09] |
User266903 - Posts: 26 |
Copy the .cht file (the chartbook). This will duplicate the entire chartbook with all charts. If you need just a chart from that chartbook, copy the chartbook > duplicate the chart and then throw away the copied chartbook. The .cht files are in your Data directory in the Sierra installation directory. |
[2016-01-22 04:46:29] |
Refer to the documentation here for this: http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
