Date/Time: Sat, 04 May 2024 12:22:32 +0000
lost charts
View Count: 1285
[2013-06-26 17:39:13] |
james d hess - Posts: 2 |
I down loaded new verision and have lost all my saved chart analysis. What to do?
[2013-06-26 19:40:57] |
Are you saying that when you select File >> Open Chartbook, you do not see your saved Chartbooks? Or what more precisely is the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
