Date/Time: Sun, 05 May 2024 09:10:22 +0000
Characteristic of Limit Orders In Chart Trade Mode
View Count: 1532
[2013-06-26 15:45:31] |
ged - Posts: 233 |
I use SC's chart trade mode (with IQ data/IB Broker). When I drag and drop a limit order on my chart it quickly snaps back to where it was and then immediately snaps back to where I have dropped it. Because the chart trade mode has always worked in this way for me, I have accepted this as 'normal', but not the most desirable. I'd rather the limit order would stay put where I drop it without the snap back and forth. Now, I just completed helping a friend get set up with SC. He also uses SC/IB and trades the same instrument(s) that I do. I notice that when he drags and drops a limit order in chart trade mode it does stay put where he drops it - there is no snap back to where it came from followed by a snap back to where he dropped it. As far as I know, all of his settings are the same as mine (I set them up). Do you have a suggestion of an adjustment I can make to prevent my chart limit orders from snapping back and forth as they are? Thanks much. |
[2013-06-26 16:48:32] |
We have an idea how this can be solved. We will implement this in the next release and see how it goes. Should be fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-08 20:46:27] |
ged - Posts: 233 |
Pre Release V993 certainly did fix this issue. Thank you very much! I notice in V993 that when I click on the right chart scale to access the scale menu, the check mark that indicates what mode the scale is in is no longer visible. |
[2013-07-09 03:04:21] |
Fixed. I notice in V993 that when I click on the right chart scale to access the scale menu, the check mark that indicates what mode the scale is in is no longer visible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-09 04:15:21
