Date/Time: Sun, 19 May 2024 13:52:48 +0000
Using Halfback for TPO/Market Profile Studies
View Count: 3899
[2016-01-19 01:03:03] |
User417726 - Posts: 9 |
Hello, I am a Sierra Chart level 5 user with AMP. I've been reading other posts about trying to implement halfback for Market Profile. It seems there is some difficulty trying to explain what it is. I linked a James Dalton video from YouTube to help. It should be easy to put in Sierra Chart as it shouldn't take much code and would be a great tool/asset for traders. https://www.youtube.com/watch?v=J4SqkwZQsw4 From 43:50 to 45:50 It would be great if an engineer from Sierra Chart would put this into the platform thanks! |
[2016-01-19 03:18:59] |
Before we look at the video have a look at the "TPO Midpoint Calculation Method" Input setting: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TPOMidpointCalculationMethod Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-19 03:23:32
[2016-01-19 15:50:14] |
Thanks for the response Yup your right, I didnt know what Midpoint meant. Thanks for the link! |
[2018-06-10 08:43:34] |
User164231 - Posts: 278 |
Hi Team SC, IS it possible to have a stand alone study that shows the mid point of an intra-day chart? Thanks |
[2018-06-11 17:45:38] |
You could use the Daily OHLC study and then display the high low average line. Refer to: Daily OHLC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-13 17:36:08] |
Thanks. Would it be possible to register a 'bread crumb' line as it goes through each candle? What I see now only shows a horizontal line based on last price. By showing a historical line I could see its relationship with the price action. Thanks again.
