Date/Time: Fri, 03 May 2024 14:44:16 +0000
Color bar based on above/below study- markers out of alignment
View Count: 2041
[2013-06-26 07:47:19] |
James235 - Posts: 2 |
I use chart markers centered over indicators. For instance an up arrow centered over a stochastic when it is below an oversold horizontal line. I just downloaded SC 990 and now, when I change chart symbols, the markers all go to the top of their respective region and are no longer clearly visible. I have to reload the chart analysis template to recenter the arrows, dots, whatever. I go through a lot of charts midday and this is tedious. There is no log entry triggered. This has never happened before. Any ideas? By the way, this software is great! |
[2013-06-27 02:04:03] |
Please provide an image of the chart, before and after you see the issue. Here are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-27 10:15:43] |
http://www.sierrachart.com/image.php?l=1372327906685.png http://www.sierrachart.com/image.php?l=1372327983585.png Here are before and after shots of Relative Momentum Index with overbought/oversold dots. |
[2013-06-30 18:31:49] |
This is a complex set up. Cannot think of anything that would of changed that would cause an issue. This might have something to do with the study calculation order. This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#StudyCalculationPrecedence Also, check the scale of the studies to make sure they make sense based upon what you are doing: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html If you still need help, we need to get a Chartbook with a single chart demonstrating the issue. Here are the instructions to provide it: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-30 19:04:37
