Date/Time: Sat, 12 Jul 2025 07:17:52 +0000
Break Out
View Count: 3040
[2016-01-14 16:42:10]
User297539 - Posts: 55
Hi SC,.
There is a Break Out in Sierra Chart study collection Indicator
image14-01-2016 17-37-21.jpg / V - Attached On 2016-01-14 16:41:24 UTC - Size: 54.06 KB - 1462 views
image14-01-2016 17-37-56.jpg / V - Attached On 2016-01-14 16:41:28 UTC - Size: 46.63 KB - 850 views
image14-01-2016 17-39-01.jpg / V - Attached On 2016-01-14 16:41:33 UTC - Size: 49.07 KB - 1125 views
[2016-01-14 18:27:08]
This is not supported in Sierra Chart. It is possible to draw high and low lines across a specified time range by using the High/Low for Time Period study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s313
[2016-01-14 19:08:25]
Sawtooth - Posts: 4238
Here's a possible spreadsheet study solution that could be modified to do this:
hourly opening range
See posts #8 and $14
[2021-06-30 02:06:45]
whats1thingnow - Posts: 407
anyone come across an indicator to show trading ranges, or potential breakouts/breakdowns like post #1?
@tomgilb, seems like spreadsheet solution works for ranges at specified times, any ideas on how to do so it shows when ranges are formed at anytime on the chart?
thank you all
