Date/Time: Mon, 29 Apr 2024 12:45:08 +0000
TPO
View Count: 1766
[2013-06-26 04:54:14] |
User28682 - Posts: 233 |
Hi, I have a TPO chart setup. I cant figure out how to have the chart show ONLY a VOLUME profile...no price hits. I am assuming its in the studies/settings section and configuring colors? Thanks Tom |
[2013-06-26 05:03:18] |
ganz - Posts: 1048 |
User28682 hi try these exmpls http://www.sierrachart.com/supportboard/showthread.php?t=40102 gd lck |
[2013-06-26 13:53:06] |
Hi, thanks for the response. When I go to try and copy this into the data folder, my computer doesnt know how to open it? I tried dragging it in but it needs to be downloaded I think?: File Type: stdycollct vp_oh.StdyCollct Tom |
[2013-06-26 13:56:13] |
User28682 hi just copy vp_oh.StdyCollct to X:\SierraChart\Data\ then do Analysis -> vp_oh In order to get rid of bars: F5 -> Graph Type -> Blank gd lck |
[2013-06-26 14:25:21] |
Here was the advice from Ganz: if so - just copy vp_oh.StdyCollct to X:\SierraChart\Data\ then do Analysis -> vp_oh In order to get rid of bars: F5 -> Graph Type -> Blank I copied (couldnt download) it into the SC data file, but dont see anything beyond that. Its in the data folder but nothng else...not sure where to go with it. I use DTN IQ. Thanks Tom |
[2013-06-26 14:45:14] |
User28682 hi just copy vp_oh.StdyCollct to X:\SierraChart\Data\ then do Analysis -> vp_oh In order to get rid of bars: F5 -> Graph Type -> Blank gd lck Thanks what is Analysis -> vp_oh? If I go the analysis tab up top, there is nothing there for vp? Tom |
[2013-06-26 14:51:28] |
User28682 http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html#Files gd lck |
[2013-06-26 15:34:18] |
so if I have put the vp_oh.StdyCollct into the SC data folder (which I did, but its a GIF, wont let me put/copy it in any other way) then it should show up in the analysis list under clean chart? Thanks for your help Tom |
SC_data_folder.png / V - Attached On 2013-06-26 15:34:03 UTC - Size: 70.34 KB - 515 views |
[2013-06-26 15:41:19] |
User28682 You need to download this file. gd lck |
vp_oh.StdyCollct - Attached On 2013-06-26 15:40:45 UTC - Size: 7.67 KB - 495 views |
[2013-06-26 15:58:07] |
Thanks, I understand...when I try and download it, it says windows cant ope the file. It needs to know what program to use to DL it? Tom |
[2013-06-26 16:02:29] |
User28682 I'm not sure /because on Linux/ but try to click the right button and Save As... gd lck |
[2013-06-26 16:19:57] |
Thanks again...ya, no matter what I try to do to DL it, it doesnt work. Can you attach it to an email in a different format? tymmot89@gmail.com Tom |
[2013-06-26 16:23:13] |
User28682 try this one / unzip it / gd lck |
vp_oh.StdyCollct.zip - Attached On 2013-06-26 16:23:07 UTC - Size: 477 B - 462 views |
[2013-06-26 16:39:05] |
Thanks...same I got this message: File Type: Unknown Description: Windows does not recognize this file type. Tom |
[2013-06-26 16:45:39] |
User28682 i've sent the email. but I can't help you w windoze. gd lck Date Time Of Last Edit: 2013-06-26 16:46:05
[2013-06-26 17:20:50] |
User28682 vp_oh uses http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html gd lck |
[2013-07-06 01:04:45] |
Here are the general instructions to work with Study Collection files: https://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html#SC If you want only a Volume by Price study on the chart, then add that study and do not use the TPO Profile Chart study. To hide the chart bars select Chart >> Graph Draw Types >> Blank. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
