Date/Time: Sat, 18 May 2024 21:54:47 +0000
Mouse sensitivity at its lowest low
View Count: 773
[2016-01-13 19:48:26] |
AP - Posts: 117 |
Now, this is only on the SC application - other apps on the windows that I am using are working all good. I literally have to click twice to activate any area on the application. My application set up has been also been the same as in the past. This happened only since past couple of days. Changed my mouse battery as well. I am sure it is the application. Any reason - you know when and why does it happen? Also, what can I do about it? |
[2016-01-13 20:45:31] |
This is going to be a system issue. Maybe you have a problem with high CPU usage: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html We definitely cannot provide any further help on this and we cannot be relied on to solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-13 20:46:04
