Date/Time: Sat, 18 May 2024 19:03:45 +0000
Zero values on Numbers Bars
View Count: 668
[2016-01-13 18:36:15] |
User74018 - Posts: 6 |
Hi! I started using Numbers Bars and noticed zero values on NQ market today from 11:56 to 12:02 chicago time. Last bar was half zeroes and half normal volume numbers. But the price was moving , as i see on chart , only with zero bid/ask volume. Did i miss something? Can someone clarify this for me? |
[2016-01-13 19:02:28] |
You are definitely going to have this problem with Interactive Brokers data. You must use the Sierra Chart Exchange Data Feed instead: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
