Date/Time: Sun, 19 May 2024 01:11:38 +0000
Draw Styles Compress Main Price Graph
View Count: 610
[2016-01-13 08:30:46] |
Halco - Posts: 92 |
When I try to use a Draw Style symbol such as an arrow in the main price graph it compresses the bars flat to the bottom of the pane. I'm sure there's some simple fix but I can't figure out the problem. Thanks.
[2016-01-13 08:36:14] |
What study is this being used with?
[2016-01-13 08:43:55] |
Halco - Posts: 92 |
Color Bar on Alert Condition. Is that the problem, that it will only work with "Color Bar" Draw Style? And the alert is based on MACD and Stochastic levels. Date Time Of Last Edit: 2016-01-13 08:50:38
[2016-01-13 12:27:40] |
Halco - Posts: 92 |
Never mind. I got it. Thanks.
[2016-01-13 18:28:24] |
For future reference what you want to do is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
