Date/Time: Sun, 19 May 2024 00:03:36 +0000
Setting an alert
View Count: 583
[2016-01-13 03:31:51] |
WilsonFisk - Posts: 5 |
I am trying to program a simple alert that sounds off when my custom study fires off a long or short signal which prints on the chart. The 2 subgraph conditions are: Long signal confirmation (SG3) which draws a Triangle up and Short signal confirmation (SG4) which draws a Triangle down. What is the proper way to word the alert so it will fire off when either of these conditions comes into effect? Thank you in advance!! |
[2016-01-13 03:45:27] |
This is the formula: =OR(SG3 <> 0, SG4 <> 0) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
