Date/Time: Sun, 19 May 2024 06:25:02 +0000
[User Discussion] - CQG
View Count: 941
[2016-01-12 21:23:32] |
crazybears - Posts: 314 |
Hi to all that are using CQG ,please i need your help, could you check if there is a loss of data you are received? I'm comparing 1 min. chart of different instruments between SC charts and NT charts, NT has CQG as datafeed too, and every day on SC charts there are wrong candles. why do i assume that SC charts are wrong ? because after delete and download data candles on SC charts are redrawn and are identical to NT charts. i check everything on my PC,and SC configuration and found nothing that can interfere, clock is synced every 3 min. they aren't lots of candles , in all session less than 10 are wrong , but it's annoying and i think to change to Rithmic if i don't find a solution. Rithmic users please give me your feedback about it . I'd like to know about as it works in real-time data and historical back-fill , i think it uses SC data. thanks |
[2016-01-12 21:46:26] |
Make sure you have Global Settings >> Data/Trade Service Settings >> Other Settings >> Allow Server to Drop Data set to false. To our knowledge that is the only setting which would cause a problem like this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-12 21:48:09
[2016-01-12 23:35:22] |
User11942 - Posts: 298 |
I don't have problems like you do with CQG. But from my personal experience CQG feed is better than Rithmic and to my knowledge CQG matches some other professional feeds. I found Rithmic real-time volumes and bid/ask trades data not always matching those of CQG. Not sure, but I always thought a backfill should come from SC when using Rithmic. I also tried NT with both feeds and they don't match there as well. The only advantage of Rithmic for me is free EUREX (not sure about data quality though but I don't care that much about that b/c I don't trade EUREX contracts intraday). Fills are acceptable with both CQG and Rithmic (but the best fills I get with Interactive Brokers).
Date Time Of Last Edit: 2016-01-13 00:20:19
