Date/Time: Mon, 29 Apr 2024 05:30:52 +0000
Correct TPOs for ZN, 6E, GC, etc.
View Count: 2116
[2013-06-25 22:53:23] |
HedgeTrader - Posts: 6 |
I would think this would be an easy resolve but I just can't figure out how to get this right. What I'm trying to do is create a 10 minute TPO opening period for markets that have a RTH open at 8:20AM EST and then have the normal 30 minute TPOs for the remainder of the RTH session. I had this with CQG IC but can't figure out how to do it with Sierra. Its odd to have a new TPO bracket start at a time other than each normal half hour TPO period just because the RTH session starts 10 minutes earlier than the normal half hour swing. Any ideas would be greatly appreciated. |
[2013-06-25 23:00:30] |
This is not supported. The only thing you can do is set the Session Start Time to 8:30.
[2013-06-25 23:02:06] |
OK, I'd appreciate if this were supported. The thought of "deleting" 10 minutes just to get the TPOs to plot correctly is simply not a good idea. A lot can occur within that first 10 minutes such as trade opportunities. Please think this through as your indicator is not plotting correctly and if you want to cater to Market Profile traders, I highly recommend you consider implementing this. Thank you! Date Time Of Last Edit: 2013-06-25 23:21:22
[2013-06-25 23:33:26] |
We will have to look into this later. We have a huge backlog now and there's no chance we are even going to look at this until next year. Just giving you the basic facts. We are not taking any new requests right now. We also assume that you have considered setting the start time to 8:00. When we mentioned 8:30, we did not mean to remove the first 10 minutes. We thought that the End Time would be 8:29:59. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-25 23:34:43
[2013-06-25 23:46:50] |
OK, thank you! The problem with using a start at 8:00 would create a potential high or low level that is not within the confines of the RTH session. That simply would not work either. Anyway, I appreciate your feedback and hope that there's some way you guys can sneak this small improvement in sooner rather than later. Thanks again! |
[2013-06-27 01:35:32] |
We gave this some thought, and we see how we can do this relatively easily . We can create a separate subperiod for the first 10 minutes of trading.
[2013-06-27 12:49:41] |
That's perfect! Thank you! I'm glad its an easy modification.
