Date/Time: Sat, 18 May 2024 20:19:59 +0000
Data transfer to new installation
View Count: 573
[2016-01-12 20:10:31] |
drak33 - Posts: 20 |
Hello, is it somehow possible to transfer the Global Settings data from an old SC installation to the new installation? I copied the folder SierraChart\Data to the new installation, but Global Settings are not transferred. For example background color, candlestick color, customized toolbars, chart trade settings ... Are this data somewhere saved, or I must to set it all manually? Thanks
[2016-01-12 21:55:33] |
Refer to help topic 15 for this: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
