Date/Time: Mon, 20 May 2024 03:05:15 +0000
Bar formation delay
View Count: 634
[2016-01-12 16:27:19] |
trader1 - Posts: 128 |
Hi, I am noticing a slight delay in the formation of the bars on the chart that didn't used to be happening. I am using 1, 3, and 5 min candles and it is happening on every time frame. What happens is the price of the last trade will be below or above the bar shown on the chart and in a second or two the chart will catch up with the price. It used to be that the top or bottom of the latest bar was equal to the current price. Can you please tell me how to correct this? Thanks. |
[2016-01-12 17:34:27] |
We see you are using Interactive Brokers. Therefore, refer to: Interactive Brokers Trading Service: Using Interactive Brokers True Real-Time Bar Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
