Date/Time: Sun, 19 May 2024 04:55:57 +0000
Real time SC FXCM CFD GER 30 feed seems to have stopped
View Count: 767
[2016-01-12 15:16:38] |
Spinoza - Posts: 62 |
[2016-01-12 15:21:08] |
User609105 - Posts: 28 |
Yeah, see my post below. All CFD look like they are frozen. Just Dax for you, or others? |
[2016-01-12 15:44:22] |
Seems to be ok now
[2016-01-12 17:28:06] |
We will be patching the missing data at the end of the day.
[2016-01-13 03:42:03] |
FXCM had a CFD data problem earlier which was the cause of this. The missing data has now been patched for most of the CFD symbols. Here are instructions to re-download the data: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
