Date/Time: Wed, 28 Oct 2026 11:59:29 +0000
Pivot Range
View Count: 1450
| [2016-01-12 13:45:05] |
| User40526 - Posts: 166 |
Is there any way to make the pivot range fill more transparent, as we can do with Market Profile. Thanks |
| [2016-01-12 17:42:00] |
We are not understanding this. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-12 18:24:58] |
http://www.sierrachart.com/image.php?l=1452622923950.png With Market Profile I can make the overlay more or less transparent so I can see the price bars more clearly. With Pivot Range, I cannot and the price bars are harder to follow. Thanks |
| [2016-01-12 18:36:40] |
This can be done by using a transparent Draw Style. Refer to: Chart Studies: Notes about Top and Bottom Draw Style Pairs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-12 21:22:30] |
I must have missed something. I believe I followed the instructions correctly, and changed the Transparency Level for Fill Styles to 25 from 75, but there is no change in the Pivot Range transparency. I even tried increasing it, thinking I was going the wrong way, but no change. Please advise. I tried to upload an image of the Graphics Settings - Other - Transparency Level for Fill Styles for you to see, but couldn't without closing the pop up. This is the image with a setting of 25. http://www.sierrachart.com/image.php?l=1452633475118.png |
| [2016-01-13 02:58:34] |
What are the names of the Draw Styles you are using now for the Pivot Range study?
| [2016-01-13 12:28:29] |
Fill Rectangle Top and Fill Rectangle Bottom, which was the default setting. I have tried to change those settings to see if that would help, to no avail. Thanks |
| [2016-01-13 14:30:25] |
Those are not transparent Draw Styles. You need to use Transparent Fill Rectangle Top and Transparent Fill Rectangle Bottom. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-13 14:56:59] |
YEA!!!! THANK YOU |
