Date/Time: Sun, 05 May 2024 22:37:56 +0000
Quick Clarification on SC.Index
View Count: 1616
[2013-06-25 19:20:11] |
User45685 - Posts: 36 |
Dear Sierra Support, when using sc.Index, will the newest bar or the oldest bar on the chart have an index of 0/1? I.e are bars indexed like in the first or second picture? (assuming these are all the bars available for view in the current chart window) http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=705 http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=706 |
scindex.PNG / V - Attached On 2013-06-25 19:19:50 UTC - Size: 24.4 KB - 773 views scindex2.PNG / V - Attached On 2013-06-25 19:19:53 UTC - Size: 24.51 KB - 788 views |
[2013-06-25 20:46:44] |
Sierra Chart - Max - Posts: 5605 |
Please refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_ACS_ArraysAndLooping.html#ArrayIndexing Sierra Chart Support Date Time Of Last Edit: 2013-06-25 22:01:59
[2013-06-25 22:10:28] |
The 2nd picture is correct. The documentation has been updated to make this clear: https://www.sierrachart.com/index.php?l=doc/doc_ACS_ArraysAndLooping.html#ArrayIndexing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-25 23:17:44] |
Thanks! Stage one of my indicator completed! :D |
