Date/Time: Mon, 20 May 2024 00:55:09 +0000
SC Data Feed down
View Count: 571
[2016-01-12 10:17:25] |
Futurestrader77 - Posts: 126 |
It is the second time this morning, that the SC Data Feed is down just for a few seconds. Please take a look into it. Thank you!
[2016-01-12 10:23:26] |
This was the result of a software update. So when we do that, some users are disconnected from the server being updated and then switched over to the other server. This happens within about three seconds. However, there will should only been one interruption for just about two or three seconds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
