Date/Time: Sun, 19 May 2024 23:32:56 +0000
connection details for Global data feeds india
View Count: 830
[2016-01-12 05:42:14] |
User5742 - Posts: 2 |
Please help me with the following Software version: 1353 | 2016-01-12 04:30:31 Uses New Spreadsheets | 2016-01-12 04:30:31 Usage end date: 2016-01-18 | 2016-01-12 04:30:31 Enabled for: Advanced Features. | 2016-01-12 04:30:31 Enabled for: Advanced Features 2. | 2016-01-12 04:30:31 Enabled for: Sierra Chart Historical Data Service. | 2016-01-12 04:30:31 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-01-12 04:30:31 Current selected Data/Trading service: SC Data - All Services | 2016-01-12 04:30:31 Chart Update Interval: 500 | 2016-01-12 04:30:31 Time Zone: +00:00:00 (UTC+00) | 2016-01-12 04:30:31 2016-01-12 10:00:31 Local computer time | 2016-01-12 04:30:31 2016-01-12 04:30:31 Local computer time in UTC | 2016-01-12 04:30:31 2016-01-12 04:30:31 Local computer time in SC Time Zone | 2016-01-12 04:30:31 2016-01-12 04:30:29 Server time in UTC | 2016-01-12 04:30:31 Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-01-12 04:30:31 Program path: C:\SierraChart\ | 2016-01-12 04:30:31 Data Files path: C:\SierraChart\Data\ | 2016-01-12 04:30:31 OS Version Number: 6.1 | 2016-01-12 04:30:31 Locale Information: C | 2016-01-12 04:30:31 Checking for new symbol settings for scdataallservices | 2016-01-12 04:30:31 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-12 04:30:31 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-01-12 04:30:32 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-01-12 04:30:32 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-01-12 04:30:32 Requesting symbol settings for scdataallservices. Overwrite = on. | 2016-01-12 04:30:35 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:29 GDF FIX Data socket (86) | Connected. | 2016-01-12 11:02:29 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:29 GDF FIX Data socket (86) | Closed. No error. | 2016-01-12 11:02:29 GDF FIX Data socket (86) | Shutdown and closed. | 2016-01-12 11:02:29 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:29 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:29 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:29 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:32 GDF FIX Data socket (88) | Connected. | 2016-01-12 11:02:32 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:32 GDF FIX Data socket (88) | Closed. No error. | 2016-01-12 11:02:32 GDF FIX Data socket (88) | Shutdown and closed. | 2016-01-12 11:02:32 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:32 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:32 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:32 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:35 GDF FIX Data socket (89) | Connected. | 2016-01-12 11:02:36 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:36 GDF FIX Data socket (89) | Closed. No error. | 2016-01-12 11:02:36 GDF FIX Data socket (89) | Shutdown and closed. | 2016-01-12 11:02:36 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:36 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:36 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:36 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:39 GDF FIX Data socket (90) | Connected. | 2016-01-12 11:02:39 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:39 GDF FIX Data socket (90) | Closed. No error. | 2016-01-12 11:02:39 GDF FIX Data socket (90) | Shutdown and closed. | 2016-01-12 11:02:39 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:39 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:39 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:39 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:42 GDF FIX Data socket (91) | Connected. | 2016-01-12 11:02:42 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:43 GDF FIX Data socket (91) | Closed. No error. | 2016-01-12 11:02:43 GDF FIX Data socket (91) | Shutdown and closed. | 2016-01-12 11:02:43 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:43 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:43 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:43 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:46 GDF FIX Data socket (92) | Connected. | 2016-01-12 11:02:46 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:46 GDF FIX Data socket (92) | Closed. No error. | 2016-01-12 11:02:46 GDF FIX Data socket (92) | Shutdown and closed. | 2016-01-12 11:02:46 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:46 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:46 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:46 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:49 GDF FIX Data socket (93) | Connected. | 2016-01-12 11:02:49 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:49 GDF FIX Data socket (93) | Closed. No error. | 2016-01-12 11:02:49 GDF FIX Data socket (93) | Shutdown and closed. | 2016-01-12 11:02:49 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:49 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:49 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:49 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:52 GDF FIX Data socket (94) | Connected. | 2016-01-12 11:02:53 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:53 GDF FIX Data socket (94) | Closed. No error. | 2016-01-12 11:02:53 GDF FIX Data socket (94) | Shutdown and closed. | 2016-01-12 11:02:53 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:53 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:53 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:53 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:02:56 GDF FIX Data socket (95) | Connected. | 2016-01-12 11:02:56 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:02:56 GDF FIX Data socket (95) | Closed. No error. | 2016-01-12 11:02:56 GDF FIX Data socket (95) | Shutdown and closed. | 2016-01-12 11:02:56 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:02:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:02:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:02:56 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:02:56 Disconnected from GlobalDataFeeds. | 2016-01-12 11:02:56 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:02:56 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:05:56 GDF FIX Data socket (97) | Connected. | 2016-01-12 11:05:57 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:05:57 GDF FIX Data socket (97) | Closed. No error. | 2016-01-12 11:05:57 GDF FIX Data socket (97) | Shutdown and closed. | 2016-01-12 11:05:57 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:05:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:05:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:05:57 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:05:57 Disconnected from GlobalDataFeeds. | 2016-01-12 11:05:57 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:05:57 Global Data Feeds (India) | Connecting to server 180.179.67.119. Port: 8086 | 2016-01-12 11:08:57 GDF FIX Data socket (100) | Connected. | 2016-01-12 11:08:58 GDF FIX Data: Sending the Logon message. | 2016-01-12 11:08:58 GDF FIX Data socket (100) | Closed. No error. | 2016-01-12 11:08:59 GDF FIX Data socket (100) | Shutdown and closed. | 2016-01-12 11:08:59 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:08:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:08:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:08:59 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:08:59 Disconnected from GlobalDataFeeds. | 2016-01-12 11:08:59 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-12 11:08:59 Date Time Of Last Edit: 2016-01-12 19:24:58
[2016-01-12 05:55:31] |
I tried with another server address; am i be able to get access in trial period this package Global Data Feeds (India) | Connecting to server 180.179.67.120. Port: 8086 | 2016-01-12 11:21:54 GDF FIX Data socket (110) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-01-12 11:21:55 GDF FIX Data socket (110) | Shutdown and closed. | 2016-01-12 11:21:55 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-01-12 11:21:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-12 11:21:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-12 11:21:55 Global Data Feeds (India) | Disconnected. | 2016-01-12 11:21:55 Disconnected from GlobalDataFeeds. | 2016-01-12 11:21:55 |
[2016-01-12 19:22:32] |
We apologize for the delay with the response. Global Data Feeds has had ongoing problems with their FIX data feed and has discontinued the use of it. So therefore, the data feed is no longer available to Sierra Chart. However, support for this data feed is coming soon: https://www.truedata.in/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
