Date/Time: Sat, 04 May 2024 04:53:04 +0000
Text size of Market Depth
View Count: 1426
[2013-06-25 18:28:35] |
blknsxy - Posts: 29 |
Hello, Can you please increase the Text size of the Market Depth window, or make it variable. I really would like to see the the Bid / Ask total and percentage better. Thanks |
[2013-06-25 23:19:35] |
This is controlled through the Chart Text Font. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
