Date/Time: Sat, 12 Jul 2025 00:56:46 +0000
User drawn chart tool properties in a file
View Count: 871
[2016-01-11 16:49:55]
buylosellhi - Posts: 60
Hi, I would like to write a script that looks at all the user drawn tools on a chart and outputs their properties to a file. Is it possible ? Does anyone have an existing template that does this, or could make it easier ?
Many thanks in advance...
[2016-01-11 18:16:41]
Refer to the documentation here:
Using Drawing Tools From an Advanced Custom Study
[2016-01-11 18:35:36]
Thanks for your reply. Where can I find the example code for scsf_UseToolExampleRewardRisk() function ? Its mentioned in the documentation page that the code is /ACS_Source/Studies.cpp file but I cant find it.
[2016-01-11 19:13:18]
This means your copy of Sierra Chart is not up-to-date.
We see you are running a very old version of Sierra Chart.
Date Time Of Last Edit: 2016-01-11 19:13:32
[2016-01-12 04:12:00]
Thanks. I was able to use the example code in studies.cpp but getting some weird output. I'm able to get the correct values for the dates but the values from DrawingObject.BeginValue etc are all off and dont correspond to prices on the chart.
Could you please point me in the right direction. Thanks much !
DrawingObject.UseRelativeVerticalValues = 0;
while( sc.GetUserDrawnChartDrawing(sc.ChartNumber, DRAWING_REWARD_RISK, DrawingObject, DrawingIndex) )
    SCDateTime entryDate, exitDate;
    float entryPx, stopPx, exitPx;
    entryDate = DrawingObject.EndDateTime;
    exitDate = DrawingObject.ThirdDateTime;
    entryPx = DrawingObject.EndValue;
    stopPx = DrawingObject.BeginValue;
    exitPx = DrawingObject.ThirdValue;
