Date/Time: Tue, 21 May 2024 06:25:31 +0000
cannot connect to the data feed
View Count: 715
[2016-01-11 10:45:30] |
User28330 - Posts: 11 |
Software version: 1352 | 2016-01-11 10:34:08 Uses New Spreadsheets | 2016-01-11 10:34:08 Usage end date: 2016-01-21 | 2016-01-11 10:34:08 Enabled for: Advanced Features. | 2016-01-11 10:34:08 Enabled for: Advanced Features 2. | 2016-01-11 10:34:08 Enabled for: Sierra Chart Historical Data Service. | 2016-01-11 10:34:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-01-11 10:34:08 Current selected Data/Trading service: FXCM FIX Trading | 2016-01-11 10:34:08 Chart Update Interval: 500 | 2016-01-11 10:34:08 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-01-11 10:34:08 2016-01-11 10:34:08 Local computer time | 2016-01-11 10:34:08 2016-01-11 10:34:08 Local computer time in UTC | 2016-01-11 10:34:08 2016-01-11 10:34:08 Local computer time in SC Time Zone | 2016-01-11 10:34:08 2016-01-11 10:34:03 Server time in UTC | 2016-01-11 10:34:08 Local computer UTC time and Server UTC time difference: 4 seconds. | 2016-01-11 10:34:08 Program path: C:\SierraChart\ | 2016-01-11 10:34:08 Data Files path: C:\SierraChart\Data\ | 2016-01-11 10:34:08 OS Version Number: 6.1 | 2016-01-11 10:34:08 Locale Information: C | 2016-01-11 10:34:08 Checking for new symbol settings for fxcm | 2016-01-11 10:34:08 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-11 10:34:08 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-01-11 10:34:08 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-01-11 10:34:08 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-01-11 10:34:08 Requesting symbol settings for fxcm. Overwrite = on. | 2016-01-11 10:34:08 Symbol settings received. | 2016-01-11 10:34:08 Processed received symbol settings | 2016-01-11 10:34:08 Files to Open on Start up | Opening file: EU.cht | 2016-01-11 10:34:11 Notice: The study 'ECIAnchorDeltaV0.5' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-11 10:34:11 Notice: The study 'ECIDeltaV0.5' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-01-11 10:34:11 Files to Open on Start up | Opening file: EURUSD Justin.cht | 2016-01-11 10:34:15 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-01-11 10:34:25 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-01-11 10:34:25 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-01-11 10:34:25 Using Bid/Ask average for last trade price for EURUSD | 2016-01-11 10:34:29 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2016-01-11 10:34:29 HD Request # 2 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2016-01-11 10:34:29 HD Request # 2 | Download start Date-Time: 2016-01-11 10:24:38.000 | 2016-01-11 10:34:29 HD Request # 2 | Using server: ds3.sierracharts.com port 10149 | 2016-01-11 10:34:29 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-11 10:34:29 Using Bid/Ask average for last trade price for USOil | 2016-01-11 10:34:29 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2016-01-11 10:34:29 Socket (4) | Connected. | 2016-01-11 10:34:29 HD Request # 2 | Sending historical data logon request message. | 2016-01-11 10:34:29 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:30 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:30 FXCM FIX Trading session socket (5) | Connected. | 2016-01-11 10:34:30 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:30 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "µÚx49,)q¯". | 2016-01-11 10:34:30 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:30 FXCM FIX Trading session socket (5) | Shutdown and closed. | 2016-01-11 10:34:30 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:30 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:30 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-01-11 10:24:38. Record interval: 0. Symbol: EURUSD | 2016-01-11 10:34:30 HD Request # 2 | Decompressing data. | 2016-01-11 10:34:30 HD Request # 2 | Receiving Intraday data for EURUSD starting at 2016-01-11 10:24:38 | 2016-01-11 10:34:30 HD Request # 2 | Timestamp of first Intraday data file record written: 2016-01-11 10:24:44 | 2016-01-11 10:34:30 HD Request # 2 | Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-01-11 10:34:31 Socket (4) | Shutdown and closed. | 2016-01-11 10:34:31 The network socket for historical data has been closed. | 2016-01-11 10:34:31 HD Request # 2 | Received 2004 records from 2016-01-11 10:24:38 to 2016-01-11 10:34:24 (9.8 minutes) and wrote 2001 records for EURUSD | 2016-01-11 10:34:31 HD Request # 2 | Intraday download COMPLETE for EURUSD. Completion time: 2s. Unique request ID: 1 | 2016-01-11 10:34:31 Removed historical data download ID 1 | 2016-01-11 10:34:31 HD Request # 3 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2016-01-11 10:34:31 HD Request # 3 | Download start Date-Time: 2016-01-11 10:24:30.000 | 2016-01-11 10:34:31 HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-01-11 10:34:31 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-01-11 10:34:31 Socket (6) | Connected. | 2016-01-11 10:34:31 HD Request # 3 | Sending historical data logon request message. | 2016-01-11 10:34:31 Chart #2 has tagged chart #4 for full recalculation. Chartbook: EU.cht | 2016-01-11 10:34:31 EURUSD 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: EU.cht | 2016-01-11 10:34:31 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2016-01-11 10:24:30. Record interval: 0. Symbol: USOil | 2016-01-11 10:34:32 HD Request # 3 | Decompressing data. | 2016-01-11 10:34:32 HD Request # 3 | Receiving Intraday data for USOil starting at 2016-01-11 10:24:30 | 2016-01-11 10:34:32 HD Request # 3 | Timestamp of first Intraday data file record written: 2016-01-11 10:24:48 | 2016-01-11 10:34:32 HD Request # 3 | Historical data for USOil is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-01-11 10:34:32 Socket (6) | Shutdown and closed. | 2016-01-11 10:34:32 The network socket for historical data has been closed. | 2016-01-11 10:34:32 HD Request # 3 | Received 178 records from 2016-01-11 10:24:30 to 2016-01-11 10:34:26 (9.9 minutes) and wrote 177 records for USOil | 2016-01-11 10:34:32 HD Request # 3 | Intraday download COMPLETE for USOil. Completion time: 1s. Unique request ID: 2 | 2016-01-11 10:34:32 Removed historical data download ID 2 | 2016-01-11 10:34:32 HD Request # 4 | Downloading Historical Daily chart data for EURUSD. Starting date: 2016-01-08. Service: fxcm | 2016-01-11 10:34:32 HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2016-01-11 10:34:32 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-01-11 10:34:32 Socket (7) | Connected. | 2016-01-11 10:34:32 HD Request # 4 | Sending historical data logon request message. | 2016-01-11 10:34:32 HD Request # 4 | Requesting historical Daily data starting at 2016-01-08. | 2016-01-11 10:34:32 HD Request # 4 | Decompressing data. | 2016-01-11 10:34:32 HD Request # 4 | Receiving historical Daily data for EURUSD starting at 2016-01-08 | 2016-01-11 10:34:32 Writing historical Daily data for EURUSD to the file EURUSD.dly | 2016-01-11 10:34:32 Socket (7) | Shutdown and closed. | 2016-01-11 10:34:32 The network socket for historical data has been closed. | 2016-01-11 10:34:32 HD Request # 4 | Received 2 records from 2016-01-08 00:00:00 to 2016-01-11 00:00:00 (4.0 days) and wrote 2 records for EURUSD | 2016-01-11 10:34:32 HD Request # 4 | Daily download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 3 | 2016-01-11 10:34:32 Removed historical data download ID 3 | 2016-01-11 10:34:32 EURUSD Daily #6 | Reloading chart. | 2016-01-11 10:34:33 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:34 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:34 FXCM FIX Trading session socket (8) | Connected. | 2016-01-11 10:34:34 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:34 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "¨ðkeäÈz–xh". | 2016-01-11 10:34:34 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:34 FXCM FIX Trading session socket (8) | Shutdown and closed. | 2016-01-11 10:34:34 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:34 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:34 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:37 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:37 FXCM FIX Trading session socket (9) | Connected. | 2016-01-11 10:34:37 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:37 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "S$7ZPQæ“t". | 2016-01-11 10:34:37 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:37 FXCM FIX Trading session socket (9) | Shutdown and closed. | 2016-01-11 10:34:37 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:37 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:37 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:40 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:40 FXCM FIX Trading session socket (10) | Connected. | 2016-01-11 10:34:40 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:40 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "A§5ëh·bo_s". | 2016-01-11 10:34:40 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:40 FXCM FIX Trading session socket (10) | Shutdown and closed. | 2016-01-11 10:34:40 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:40 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:40 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:43 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:43 FXCM FIX Trading session socket (11) | Connected. | 2016-01-11 10:34:43 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:44 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "=îAãÈ‚;‡Vi". | 2016-01-11 10:34:44 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:44 FXCM FIX Trading session socket (11) | Shutdown and closed. | 2016-01-11 10:34:44 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:44 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:44 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:47 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:47 FXCM FIX Trading session socket (12) | Connected. | 2016-01-11 10:34:47 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:47 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received ""ÀÙô ö"¥". | 2016-01-11 10:34:47 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:47 FXCM FIX Trading session socket (12) | Shutdown and closed. | 2016-01-11 10:34:47 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:47 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:47 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:50 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:50 FXCM FIX Trading session socket (13) | Connected. | 2016-01-11 10:34:50 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:50 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "Àe&‘HÇÈ{#Í". | 2016-01-11 10:34:50 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:50 FXCM FIX Trading session socket (13) | Shutdown and closed. | 2016-01-11 10:34:50 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:50 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:50 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:53 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:53 FXCM FIX Trading session socket (14) | Connected. | 2016-01-11 10:34:53 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:53 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "o10ÙíÛCÜ º". | 2016-01-11 10:34:53 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:53 FXCM FIX Trading session socket (14) | Shutdown and closed. | 2016-01-11 10:34:53 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:53 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:53 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:34:56 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:34:56 FXCM FIX Trading session socket (15) | Connected. | 2016-01-11 10:34:56 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:34:57 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "Ø¿\Ä@À’@". | 2016-01-11 10:34:57 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:34:57 FXCM FIX Trading session socket (15) | Shutdown and closed. | 2016-01-11 10:34:57 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:34:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:34:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:34:57 FXCM FIX Trading | Disconnected. | 2016-01-11 10:34:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:34:57 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:00 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:00 FXCM FIX Trading session socket (16) | Connected. | 2016-01-11 10:35:00 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:00 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "ç?dœÞ˜¦,߃". | 2016-01-11 10:35:00 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:00 FXCM FIX Trading session socket (16) | Shutdown and closed. | 2016-01-11 10:35:00 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:00 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:00 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:03 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:03 FXCM FIX Trading session socket (17) | Connected. | 2016-01-11 10:35:03 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:03 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "§m'öYáÕçs". | 2016-01-11 10:35:03 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:03 FXCM FIX Trading session socket (17) | Shutdown and closed. | 2016-01-11 10:35:03 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:03 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:03 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:06 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:06 FXCM FIX Trading session socket (18) | Connected. | 2016-01-11 10:35:06 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:06 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "§lplðê]ÑZ". | 2016-01-11 10:35:06 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:06 FXCM FIX Trading session socket (18) | Shutdown and closed. | 2016-01-11 10:35:06 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:06 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:06 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:10 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:10 FXCM FIX Trading session socket (19) | Connected. | 2016-01-11 10:35:10 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:10 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "ï4±p:Ó". | 2016-01-11 10:35:10 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:10 FXCM FIX Trading session socket (19) | Shutdown and closed. | 2016-01-11 10:35:10 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:10 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:10 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:13 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:13 FXCM FIX Trading session socket (20) | Connected. | 2016-01-11 10:35:13 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:13 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "”ã|å¤ÆY,". | 2016-01-11 10:35:13 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:13 FXCM FIX Trading session socket (20) | Shutdown and closed. | 2016-01-11 10:35:13 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:13 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:13 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:13 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:16 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:16 FXCM FIX Trading session socket (21) | Connected. | 2016-01-11 10:35:16 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:16 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "{7-BfäªP.". | 2016-01-11 10:35:16 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:16 FXCM FIX Trading session socket (21) | Shutdown and closed. | 2016-01-11 10:35:16 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:16 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:16 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:19 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:19 FXCM FIX Trading session socket (22) | Connected. | 2016-01-11 10:35:19 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:20 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received ""c×|ð9ÁOÓ". | 2016-01-11 10:35:20 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:20 FXCM FIX Trading session socket (22) | Shutdown and closed. | 2016-01-11 10:35:20 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:20 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:20 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:23 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:23 FXCM FIX Trading session socket (23) | Connected. | 2016-01-11 10:35:23 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:23 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "É(æ±q[F". | 2016-01-11 10:35:23 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:23 FXCM FIX Trading session socket (23) | Shutdown and closed. | 2016-01-11 10:35:23 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:23 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:23 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:26 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:26 FXCM FIX Trading session socket (24) | Connected. | 2016-01-11 10:35:26 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:26 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "UŽè“„W»EG". | 2016-01-11 10:35:26 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:26 FXCM FIX Trading session socket (24) | Shutdown and closed. | 2016-01-11 10:35:26 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:26 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:26 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:29 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:29 FXCM FIX Trading session socket (25) | Connected. | 2016-01-11 10:35:29 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:29 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "& | 2016-01-11 10:35:29 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:29 FXCM FIX Trading session socket (25) | Shutdown and closed. | 2016-01-11 10:35:29 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:29 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:29 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:32 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:32 FXCM FIX Trading session socket (26) | Connected. | 2016-01-11 10:35:32 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:33 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "\ˆŸØ}€". | 2016-01-11 10:35:33 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:33 FXCM FIX Trading session socket (26) | Shutdown and closed. | 2016-01-11 10:35:33 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:33 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:33 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:36 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:36 FXCM FIX Trading session socket (27) | Connected. | 2016-01-11 10:35:36 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:36 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "—rê¶1ù0x". | 2016-01-11 10:35:36 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:36 FXCM FIX Trading session socket (27) | Shutdown and closed. | 2016-01-11 10:35:36 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:36 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:36 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:39 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:39 FXCM FIX Trading session socket (28) | Connected. | 2016-01-11 10:35:39 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:39 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "ƒÚYÆ¡MÑZ+". | 2016-01-11 10:35:39 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:39 FXCM FIX Trading session socket (28) | Shutdown and closed. | 2016-01-11 10:35:39 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:39 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:39 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:42 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:42 FXCM FIX Trading session socket (29) | Connected. | 2016-01-11 10:35:42 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:42 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "dnŒ•5µ ©". | 2016-01-11 10:35:42 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:42 FXCM FIX Trading session socket (29) | Shutdown and closed. | 2016-01-11 10:35:42 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:42 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:43 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:46 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:46 FXCM FIX Trading session socket (30) | Connected. | 2016-01-11 10:35:46 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:46 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "øþ#†·c¾ÚÑ". | 2016-01-11 10:35:46 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:46 FXCM FIX Trading session socket (30) | Shutdown and closed. | 2016-01-11 10:35:46 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:46 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:46 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:49 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:49 FXCM FIX Trading session socket (31) | Connected. | 2016-01-11 10:35:49 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:49 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "$ÔÍ@Ö²Mû ú". | 2016-01-11 10:35:49 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:49 FXCM FIX Trading session socket (31) | Shutdown and closed. | 2016-01-11 10:35:49 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:49 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:49 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:52 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:52 FXCM FIX Trading session socket (32) | Connected. | 2016-01-11 10:35:52 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:52 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "¾‚ 7TM£Â". | 2016-01-11 10:35:52 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:52 FXCM FIX Trading session socket (32) | Shutdown and closed. | 2016-01-11 10:35:52 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:52 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:52 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:55 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:55 FXCM FIX Trading session socket (33) | Connected. | 2016-01-11 10:35:55 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:56 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "M$KLê¿ÿ8y". | 2016-01-11 10:35:56 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:56 FXCM FIX Trading session socket (33) | Shutdown and closed. | 2016-01-11 10:35:56 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:56 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:56 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:35:59 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:35:59 FXCM FIX Trading session socket (34) | Connected. | 2016-01-11 10:35:59 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:35:59 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "Ðló!œ÷•+@ˆ". | 2016-01-11 10:35:59 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:35:59 FXCM FIX Trading session socket (34) | Shutdown and closed. | 2016-01-11 10:35:59 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:35:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:35:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:35:59 FXCM FIX Trading | Disconnected. | 2016-01-11 10:35:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:35:59 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:36:02 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:36:02 FXCM FIX Trading session socket (35) | Connected. | 2016-01-11 10:36:02 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:36:02 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "†VÍ#Vž@Iö". | 2016-01-11 10:36:02 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:36:02 FXCM FIX Trading session socket (35) | Shutdown and closed. | 2016-01-11 10:36:02 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:36:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:36:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:36:02 FXCM FIX Trading | Disconnected. | 2016-01-11 10:36:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:36:02 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:36:05 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:36:05 FXCM FIX Trading session socket (36) | Connected. | 2016-01-11 10:36:05 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:36:05 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received " | 2016-01-11 10:36:05 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:36:05 FXCM FIX Trading session socket (36) | Shutdown and closed. | 2016-01-11 10:36:05 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:36:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:36:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:36:05 FXCM FIX Trading | Disconnected. | 2016-01-11 10:36:05 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:36:05 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:39:05 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:39:05 FXCM FIX Trading session socket (39) | Connected. | 2016-01-11 10:39:05 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:39:06 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "–mËI~÷P". | 2016-01-11 10:39:06 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:39:06 FXCM FIX Trading session socket (39) | Shutdown and closed. | 2016-01-11 10:39:06 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:39:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:39:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:39:06 FXCM FIX Trading | Disconnected. | 2016-01-11 10:39:06 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:39:06 FXCM FIX Trading session | Connecting to address . Port 80. | 2016-01-11 10:42:06 FXCM FIX Trading session socket (0) | Resolved address Alin-PC to IP 192.168.1.5 | 2016-01-11 10:42:06 FXCM FIX Trading session socket (41) | Connected. | 2016-01-11 10:42:06 FXCM FIX Trading session: Sending the Logon message. | 2016-01-11 10:42:06 FXCM FIX Trading session: Received data that does not match the expected FIX protocol. Expected "8=FIX.4.4" but received "Îk¡x7—ë$à". | 2016-01-11 10:42:06 * FXCM FIX Trading session: Sending a Logout message. Text = Data received does not match expected FIX protocol. | 2016-01-11 10:42:06 FXCM FIX Trading session socket (41) | Shutdown and closed. | 2016-01-11 10:42:06 FXCM FIX Trading session: Disconnected. | 2016-01-11 10:42:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-01-11 10:42:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-01-11 10:42:06 FXCM FIX Trading | Disconnected. | 2016-01-11 10:42:06 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-01-11 10:42:06 |
[2016-01-11 10:50:59] |
Did you just require Forex market data? You are trying to connect to the FXCM FIX trading server. Do you have a live FXCM account? If you just want market data set Global Settings >> Data/Trade Service Settings >> Service to "SC Forex Data" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
