Date/Time: Tue, 21 May 2024 11:07:12 +0000
KC-MH6 Coffee Futures
View Count: 1828
[2016-01-11 02:41:18] |
User438810 - Posts: 50 |
My Coffee charts on the intraday timeframe have a gap and it won't update. Is it on my end? I did delete all and download data already.
[2016-01-11 03:38:29] |
We do not see any active trading now for March coffee on the ICE, at this time.
[2016-01-11 06:21:38] |
My apologies. I meant there's a huge misprint on the 120min, 60min charts, while the daily and weekly are fine. I attached a file that shows this. I use OEC data. Thanks again! |
KC-MH6 (OEC data).png / V - Attached On 2016-01-11 06:19:36 UTC - Size: 117.26 KB - 280 views Attachment Deleted. |
[2016-01-11 06:57:05] |
This is now solved. Re-download the data in the chart with Edit >> Delete All Data and Download.
