Date/Time: Wed, 22 May 2024 00:25:55 +0000
Problem with Vortex study
View Count: 895
[2016-01-10 16:24:40] |
User166870 - Posts: 13 |
The study values are always set to 1 ?
[2016-01-10 21:04:08] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-11 11:18:57] |
It seems to appear only with E-Mini Dow (YM) Take a look at the VM+/VM- values, please. |
[2016-01-11 11:20:25] |
http://www.sierrachart.com/image.php?l=145251109473.png http://www.sierrachart.com/image.php?l=1452511215400.png |
[2016-01-11 13:30:28] |
Outlander - Posts: 91 |
Change the Value format
[2016-01-11 13:39:29] |
That was the problem, many thanks !
[2016-01-11 18:51:15] |
Yes, the problem is the Value Format setting on the study. It needs to be set to .001.
