Date/Time: Sat, 27 Apr 2024 09:41:25 +0000
Sierra charts / LMAX
View Count: 2886
[2013-06-25 16:41:35] |
User41512 - Posts: 58 |
Hi , A/ I currently use LMAX as my current broker. Do i have the option of trading through Sierra charts directly into my brokers platform, and/or could i use sierra charts as a standalone package. b/ Please Can you confirm that Sierra charts would work with DTN IQ data feed. c/ What are the minimum Specifications required in order to run Sierra charts on a laptop/PC c/ How quickly does the process take if i want to proceed with purchasing a level 5 sierra charts package. D/ Can you confirm that the cost at present would be fixed $45 per month. Thks |
[2013-06-25 17:34:16] |
1. Sierra Chart fully supports LMAX. You can use LMAX market data and trade directly from Sierra Chart using your LMAX account. Complete details can be found here: https://www.sierrachart.com/index.php?l=doc/LMAX.php Sierra Chart is a complete standalone package that will give you everything you need. 2. Yes, Sierra Chart supports DTN IQ Data feed. 3. We recommend at least a dual core and 2 gigabytes of memory. For disk space you should have about 100 megabytes free. This is used for data. 4. It is immediate. 5. Yes. If you pay for multiple months you get a discount. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-25 19:04:08] |
fxz - Posts: 32 |
Please stay on FIX with LMAX because is the most reliable way to use their servers, no fees are applied if you trade few millions per month, there are other forex pools for non pro traders Thanks Date Time Of Last Edit: 2013-08-25 19:04:35
[2013-08-25 19:24:53] |
fxz - Posts: 32 |
i need to set up my LMAX FIX account on SC and they provided these settings can i fill them as on Currenex , i need to fill these parameters Market Data:- DNS: fixdata.lmaxtrader.com TargetCompId: LMX123 Port: 443 SenderCompId: mycomputer Username: Password: Trading:- DNS: fixtrade.lmaxtrader.com TargetCompId: LMXabc Port: 443 SenderCompId: mycomputer Username: Password: Date Time Of Last Edit: 2013-08-26 07:28:32
[2013-08-26 01:00:14] |
Select the LMAX Trading service in Global Settings >>Data/Trade Service Settings. You will want to choose to use the Live server. The SenderCompId is equivalent to the Username. And enter the password as the password. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-26 06:20:49] |
fxz - Posts: 32 |
Hi i d need to switch between different LMAX environments and servers locations, fields as for currenex and any FIX dts are essential to be freely customizable Thanks Date Time Of Last Edit: 2013-08-26 06:36:46
[2013-08-26 06:42:32] |
So you need to be able to set the connection address?
[2013-08-26 06:47:17] |
fxz - Posts: 32 |
Yes they ask also targetcompid for both Trading and Data Date Time Of Last Edit: 2013-08-26 06:49:16
[2013-08-26 19:03:19] |
Fraois - Posts: 12 |
How did you retrieve historical data via FIX? I thought FIX doesn't allow you to do that but only execute trades or retrieve quotes, I like FIX anyway.
Date Time Of Last Edit: 2013-08-26 19:05:30
[2013-08-27 04:20:35] |
We can add custom connection settings for LMAX but this will be an additional one-time charge. We would expect this would be about 75 to 80 USD. So if you can add $75 to your account for additional services we will use that to develop this: https://www.sierrachart.com/usercp.php?page=CustomPayments In the case of LMAX, historical data is provided through Sierra Chart systems. So in the case of when using LMAX, you will have quality historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-27 04:21:13
