Date/Time: Fri, 17 May 2024 17:29:30 +0000
Auto Trade System Back Testing
View Count: 583
[2016-01-09 23:00:33] |
crazybears - Posts: 314 |
Hi I'd like if you could clarify my doubts on how data and time of bars are processed during Auto Trade System Back Testing. i set an input to flatten position and cancel order and don't trade after a certain time e.g. 16:14. when market ,due to holiday ends earlier than normal time,would be better set also a date check to force the close ? i mean, during replay ,are bars add to chart and after the study is calculated? so that you can check when there is a time or date different between 2 bars . if some example exists please could you post link? regards |
[2016-01-10 01:11:36] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php#UnderstandingCalculationTradingSystemStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
