Date/Time: Tue, 21 May 2024 20:25:49 +0000
[User Discussion] - Volume by price study request
View Count: 667
[2016-01-09 19:50:27] |
JosefPetran - Posts: 7 |
Dear Support board, I have added the VBP study (in the static intraday chart) and I would like to ask, if there si an utility, that can render the VPB according to how I manually shift the chart (candle after candle)and corresponds to the displayed (odly displayed) candles. All in the static form - manually shifted.:-). Thank you very much for your answer. BR. Josef |
[2016-01-09 19:58:35] |
Yes. You just need to set the Volume Graph Period Type Input with the Volume by Price study to "Visible Bars".
[2016-01-09 20:13:16] |
OK, an this is possible only with the ,,visible bars" profile? Meaning, in the volume graph period type? Do I understand it correctly? Thank you. Josef:-) |
[2016-01-09 20:14:58] |
Yes this is correct.
[2016-01-09 20:18:52] |
Perfect:-). And pls, one more technical question. I operate with two types of graphs 30 min + 2 min. Into the 30 min I draw some extended rectangle + lines and the question is, if it si possible, when I draw this into the 30 min graph, can it be displayed as well in to the 2 min graph togethe at the same time of drawing? Thank you very much for your answer. BR. Josef |
[2016-01-10 01:12:08] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
