Date/Time: Tue, 21 May 2024 09:48:04 +0000
Stops
View Count: 797
[2016-01-09 17:00:15] |
Richard Reyes - Posts: 98 |
How do I set a simple profit and loss stop in Sierra Charts. I would like to set a dollar (price) amount for my loss stop and the same for my profit stop? I have tried Attached Orders, but I just cannot see related changes when I adjust "MIT" and "Stop Stop". All help greatly appreciated
[2016-01-09 23:56:06] |
It is not supported to set the Attached Order offsets to an actual Profit/Loss currency value, if that is what you want to do. Only a Price offset relative to the parent order price which resolves to an actual trade price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-01-10 00:59:54] |
All I want to do is set a profit stop and a loss stop, just something simple. How do I do this? Many Thanks
[2016-01-10 01:22:29] |
Did you go through the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#AttachedOrderWindowInterface There are also some screenshots showing just what to do. Follow through the instructions. It is not hard. There is also a video here: https://www.sierrachart.com/Videos/SierraChartAttachedOrdersDemo.wmv Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-01-10 01:22:54
