Date/Time: Sat, 27 Apr 2024 19:20:51 +0000
Quoteboard Sorting
View Count: 2412
[2013-03-27 22:45:12] |
User70302 - Posts: 30 |
I am trying to set up my quoteboards. I would like to create multiple groups within one quoteboard , which I did with the "Insert Label" option. Now, I would like to sort the symbols of each group by Net change. But when sorting, the group labels dissapear and symbols are sorted regardless of which group they belong to. Any suggestions on how to get this work? |
[2013-03-27 22:58:15] |
We will look into this, but all of the symbols will be sorted as if it is one list. You really have to use separate Quote Boards to separate sorting.
[2013-03-31 03:57:15] |
Al SC Developer - Posts: 434 |
A new Quote Board menu option Settings >> Sort Within Groups will be in 960, when available.
