Date/Time: Wed, 15 May 2024 03:22:55 +0000
Volume by Price Study - Separate Colors for RTH & Evening Session Profiles
View Count: 1374
[2016-01-07 01:16:28] |
Yoda - Posts: 106 |
In the Volume by Price study, after I choose "Yes" to "Use Separate Profile For Evening Session", how can I then show the volume profiles for the RTH session and the Evening session in separate colors (i.e. to clearly show which volume profile relates to RTH and which relates to the Evening session)?
[2016-01-07 02:03:38] |
We have to add this capability. We will put it on our to do list. We should get it done near-term.
[2018-04-30 13:10:49] |
MD236 - Posts: 28 |
For me it's also very interesting to color the sessions different, do you've any solution now? Thanks |
[2018-04-30 18:41:48] |
Yes, this is now supported: Volume By Price Study: Evening Session Volume Bars Outline and Fill Colors (SG11) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-30 18:42:54
