Date/Time: Sun, 28 Apr 2024 18:07:49 +0000
2 CTS T4 accounts on 1 datafeed
View Count: 1566
[2013-06-25 13:07:30] |
KhaosTrader - Posts: 128 |
Hi, I have two CTS T4 accounts on one datafeed, how can I set it up so i can trade on both accounts at the same time on the same computer? |
[2013-06-25 16:34:38] |
It would be best, for CTS to put each account on a separate username and then to use 2 separate connections through 2 separate copies of Sierra Chart. You will have 2 copies of Sierra Chart, one connected to each T4 username. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html Otherwise, what you are looking for is not currently supported. Working with multiple accounts, in Sierra Chart is still something under development. Still it is probably about a month away. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-25 23:08:59] |
MMX - Posts: 119 |
The one and only account I have is a CTS datafeed that's cleared through Vision. Although I've never ran 2 accounts, I have read up on it in CTS's "Help", and the way I understand it is if all your accounts are with the same broker and cleared through the same clearing firm, then the CTS T4 trading platform will receive the 1 Sierra Chart order, filter it through CTS's "Group Account", and then send the orders to the floor in accordance with whatever the instructions are in the Group Account. The assumption that I'm making is that an order is an order, whether it's executed from Sierra Charts or executed from the CTS trading platform, and once received, the CTS platform will handle it accordingly. Read CTS's help section on Group Accounts and see what conclusions you come to.
