Date/Time: Wed, 28 Oct 2026 11:14:50 +0000
Help- I'm not receiving chart data
View Count: 978
[2016-01-05 15:06:16]
User62612 - Posts: 12
I have disconnected data feed and reconnected it a coupe times. It
updates history but I am not receiving continuous real time data.
[2016-01-05 15:35:12]
We see you are using CQG. Currently CQG is having some server problems at this time.
However, so we can know for sure the source of the problem provide a copy of the Message Log by following these instructions here:
[2016-01-05 15:46:13]
CQG has said this:
Were facing the same issue as we did yesterday. We are trying to sort out the issue.
Users should be patient and allow the system to catch up natuarally.
[2016-01-05 15:47:47]
User702376 - Posts: 5
I too am having this is...I have forwarded my message log via Sierra Chart.
[2016-01-05 15:49:05]
Software version: 1234 | 2016-01-05 08:44:25
Uses Old Spreadsheets | 2016-01-05 08:44:25
Usage end date: 2016-03-05 | 2016-01-05 08:44:25
Allow Support for Sierra Chart Data Feeds is disabled. | 2016-01-05 08:44:25
Active service: CQG FIX Trading | 2016-01-05 08:44:25
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-01-05 08:44:25
2016-01-05 08:44:25 Local computer clock time | 2016-01-05 08:44:25
2016-01-05 14:44:25 GMT time | 2016-01-05 08:44:25
2016-01-05 08:44:25 Time zone adjusted time | 2016-01-05 08:44:25
Time difference to server time: 0 seconds. | 2016-01-05 08:44:25
Program path: C:\SierraChart\ | 2016-01-05 08:44:25
Data Files path: C:\SierraChart\Data\ | 2016-01-05 08:44:25
OS Version Number: 5.1 | 2016-01-05 08:44:25
Locale Information: C | 2016-01-05 08:44:25
Checking for new symbol settings for cqg | 2016-01-05 08:44:25
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-01-05 08:44:25
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2016-01-05 08:44:26
Symbol settings are up-to-date for cqg | 2016-01-05 08:44:26
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-01-05 08:44:30
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-01-05 08:44:30
socket (2) | Connected. | 2016-01-05 08:44:31
CQG FIX Trading FIX: Sending the Logon message. | 2016-01-05 08:44:31
CQG FIX Trading | Connected to trading server. | 2016-01-05 08:44:31
CQG FIX Trading | Connecting to market data server. | 2016-01-05 08:44:31
Connecting to websocket server. | 2016-01-05 08:44:31
CQG FIX Trading FIX - FCM name: Advantage | 2016-01-05 08:44:31
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2016-01-05 08:44:31
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2016-01-05 08:44:31
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2016-01-05 08:44:31
Socket (3) | Connected. | 2016-01-05 08:44:31
Socket (3) | Starting SSL connection. | 2016-01-05 08:44:31
Socket (3) | SSL connection established. | 2016-01-05 08:44:32
Opening websocket. | 2016-01-05 08:44:32
Sending websocket handshake. | 2016-01-05 08:44:32
Received websocket handshake acknowledgment. | 2016-01-05 08:44:32
Web socket state is now open. | 2016-01-05 08:44:32
CQG FIX Trading | Websocket connected. | 2016-01-05 08:44:32
CQG FIX Trading | Sending market data logon message. | 2016-01-05 08:44:32
CQG FIX Trading | Logon successful. | 2016-01-05 08:44:32
CQG FIX Trading | Market data session connected. | 2016-01-05 08:44:32
CQG FIX Trading | Starting real-time market data updates for: F.US.EPH16. ID: 1 | 2016-01-05 08:44:35
CQG FIX Trading | Sending symbol resolution request for F.US.EPH16 | 2016-01-05 08:44:35
Intraday data recording state for symbol F.US.EPH16 is set to download pending. | 2016-01-05 08:44:35
HD Request # 2 | Downloading Intraday chart data for F.US.EPH16 to the file F.US.EPH16.scid. Service: cqg | 2016-01-05 08:44:36
HD Request # 2 | Download start Date-Time: 2016-01-05 08:40:05.0 | 2016-01-05 08:44:36
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-01-05 08:44:36
CQG FIX Trading | Requesting market data for F.US.EPH16 | 2016-01-05 08:44:36
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-01-05 08:44:36
Socket (4) | Connected. | 2016-01-05 08:44:36
HD Request # 2 | Sending historical data logon request message. | 2016-01-05 08:44:36
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-01-05 08:40:05. Record interval: 1. Symbol: F.US.EPH16 | 2016-01-05 08:44:36
HD Request # 2 | Decompressing data. | 2016-01-05 08:44:36
HD Request # 2 | Receiving Intraday data for F.US.EPH16 starting at 2016-01-05 08:40:05 | 2016-01-05 08:44:36
HD Request # 2 | Timestamp of first Intraday data file record written: 2016-01-05 08:40:05 | 2016-01-05 08:44:36
Socket (4) | Shutdown and closed. | 2016-01-05 08:44:36
The network socket for historical data has been closed. | 2016-01-05 08:44:36
HD Request # 2 | Received 254 records from 2016-01-05 08:40:05 to 2016-01-05 08:44:35 (4.5 minutes) and wrote 254 records for F.US.EPH16 | 2016-01-05 08:44:37
HD Request # 2 | Intraday download COMPLETE for F.US.EPH16. Completion time: 0s. Unique request ID: 1 | 2016-01-05 08:44:37
Removed historical data download ID 1 | 2016-01-05 08:44:37
Real-time Intraday chart data file updates started for F.US.EPH16 | 2016-01-05 08:44:37
File >> Disconnect selected. | 2016-01-05 08:56:04
CQG FIX Trading FIX: DisconnectFIX called. | 2016-01-05 08:56:04
CQG FIX Trading FIX: Sending a Logout message. | 2016-01-05 08:56:04
Sending logoff message. | 2016-01-05 08:56:04
Socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-05 08:56:04
Socket (3) | SSL has been shut down. | 2016-01-05 08:56:04
Socket (3) | SSL object has been freed. SSL state is now disconnected. | 2016-01-05 08:56:04
Socket (3) | Shutdown and closed. | 2016-01-05 08:56:04
CQG FIX Trading | Websocket closed. | 2016-01-05 08:56:04
CQG FIX Trading | Disconnected. | 2016-01-05 08:56:04
CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-01-05 08:56:04
socket (2) | Shutdown and closed. | 2016-01-05 08:56:04
CQG FIX Trading FIX: Logged out and disconnected. | 2016-01-05 08:56:04
CQG FIX Trading FIX: Disconnected. | 2016-01-05 08:56:04
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-01-05 08:56:10
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-01-05 08:56:10
socket (5) | Connected. | 2016-01-05 08:56:10
CQG FIX Trading FIX: Sending the Logon message. | 2016-01-05 08:56:10
CQG FIX Trading | Connected to trading server. | 2016-01-05 08:56:10
CQG FIX Trading | Connecting to market data server. | 2016-01-05 08:56:10
Connecting to websocket server. | 2016-01-05 08:56:10
CQG FIX Trading FIX - FCM name: Advantage | 2016-01-05 08:56:10
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2016-01-05 08:56:10
Socket (6) | Connected. | 2016-01-05 08:56:10
Socket (6) | Starting SSL connection. | 2016-01-05 08:56:10
Socket (6) | SSL connection established. | 2016-01-05 08:56:11
Opening websocket. | 2016-01-05 08:56:11
Sending websocket handshake. | 2016-01-05 08:56:11
Received websocket handshake acknowledgment. | 2016-01-05 08:56:11
Web socket state is now open. | 2016-01-05 08:56:11
CQG FIX Trading | Websocket connected. | 2016-01-05 08:56:11
CQG FIX Trading | Sending market data logon message. | 2016-01-05 08:56:11
CQG FIX Trading | Logon successful. | 2016-01-05 08:56:11
CQG FIX Trading | Market data session connected. | 2016-01-05 08:56:11
CQG FIX Trading | Starting real-time market data updates for: F.US.EPH16. ID: 1 | 2016-01-05 08:56:11
CQG FIX Trading | Sending symbol resolution request for F.US.EPH16 | 2016-01-05 08:56:11
Intraday data recording state for symbol F.US.EPH16 is set to download pending. | 2016-01-05 08:56:11
HD Request # 3 | Downloading Intraday chart data for F.US.EPH16 to the file F.US.EPH16.scid. Service: cqg | 2016-01-05 08:56:12
HD Request # 3 | Download start Date-Time: 2016-01-05 08:44:35.0 | 2016-01-05 08:56:12
HD Request # 3 | Using server: ds5.sierracharts.com port 10149 | 2016-01-05 08:56:12
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-01-05 08:56:12
Socket (7) | Connected. | 2016-01-05 08:56:12
HD Request # 3 | Sending historical data logon request message. | 2016-01-05 08:56:12
CQG FIX Trading | Requesting market data for F.US.EPH16 | 2016-01-05 08:56:12
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2016-01-05 08:44:35. Record interval: 1. Symbol: F.US.EPH16 | 2016-01-05 08:56:13
HD Request # 3 | Decompressing data. | 2016-01-05 08:56:13
HD Request # 3 | Receiving Intraday data for F.US.EPH16 starting at 2016-01-05 08:44:35 | 2016-01-05 08:56:13
HD Request # 3 | Timestamp of first Intraday data file record written: 2016-01-05 08:44:35 | 2016-01-05 08:56:13
Socket (7) | Shutdown and closed. | 2016-01-05 08:56:13
The network socket for historical data has been closed. | 2016-01-05 08:56:13
HD Request # 3 | Received 655 records from 2016-01-05 08:44:35 to 2016-01-05 08:56:09 (11.6 minutes) and wrote 655 records for F.US.EPH16 | 2016-01-05 08:56:13
HD Request # 3 | Intraday download COMPLETE for F.US.EPH16. Completion time: 0s. Unique request ID: 2 | 2016-01-05 08:56:13
Removed historical data download ID 2 | 2016-01-05 08:56:13
Real-time Intraday chart data file updates started for F.US.EPH16 | 2016-01-05 08:56:13
File >> Disconnect selected. | 2016-01-05 09:02:01
CQG FIX Trading FIX: DisconnectFIX called. | 2016-01-05 09:02:01
CQG FIX Trading FIX: Sending a Logout message. | 2016-01-05 09:02:01
Sending logoff message. | 2016-01-05 09:02:01
Socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-01-05 09:02:01
Socket (6) | SSL has been shut down. | 2016-01-05 09:02:01
Socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-01-05 09:02:01
Socket (6) | Shutdown and closed. | 2016-01-05 09:02:01
CQG FIX Trading | Websocket closed. | 2016-01-05 09:02:01
CQG FIX Trading | Disconnected. | 2016-01-05 09:02:01
CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-01-05 09:02:01
socket (5) | Shutdown and closed. | 2016-01-05 09:02:01
CQG FIX Trading FIX: Logged out and disconnected. | 2016-01-05 09:02:01
CQG FIX Trading FIX: Disconnected. | 2016-01-05 09:02:01
CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-01-05 09:02:07
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2016-01-05 09:02:07
socket (8) | Connected. | 2016-01-05 09:02:07
CQG FIX Trading FIX: Sending the Logon message. | 2016-01-05 09:02:07
CQG FIX Trading | Connected to trading server. | 2016-01-05 09:02:07
CQG FIX Trading | Connecting to market data server. | 2016-01-05 09:02:07
Connecting to websocket server. | 2016-01-05 09:02:07
CQG FIX Trading FIX - FCM name: Advantage | 2016-01-05 09:02:07
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2016-01-05 09:02:07
Socket (9) | Connected. | 2016-01-05 09:02:07
Socket (9) | Starting SSL connection. | 2016-01-05 09:02:07
Socket (9) | SSL connection established. | 2016-01-05 09:02:07
Opening websocket. | 2016-01-05 09:02:07
Sending websocket handshake. | 2016-01-05 09:02:07
Received websocket handshake acknowledgment. | 2016-01-05 09:02:07
Web socket state is now open. | 2016-01-05 09:02:07
CQG FIX Trading | Websocket connected. | 2016-01-05 09:02:07
CQG FIX Trading | Sending market data logon message. | 2016-01-05 09:02:07
CQG FIX Trading | Logon successful. | 2016-01-05 09:02:08
CQG FIX Trading | Market data session connected. | 2016-01-05 09:02:08
CQG FIX Trading | Starting real-time market data updates for: F.US.EPH16. ID: 1 | 2016-01-05 09:02:08
CQG FIX Trading | Sending symbol resolution request for F.US.EPH16 | 2016-01-05 09:02:08
Intraday data recording state for symbol F.US.EPH16 is set to download pending. | 2016-01-05 09:02:08
HD Request # 4 | Downloading Intraday chart data for F.US.EPH16 to the file F.US.EPH16.scid. Service: cqg | 2016-01-05 09:02:09
HD Request # 4 | Download start Date-Time: 2016-01-05 08:56:09.0 | 2016-01-05 09:02:09
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2016-01-05 09:02:09
CQG FIX Trading | Requesting market data for F.US.EPH16 | 2016-01-05 09:02:09
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-01-05 09:02:09
Socket (10) | Connected. | 2016-01-05 09:02:09
HD Request # 4 | Sending historical data logon request message. | 2016-01-05 09:02:09
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2016-01-05 08:56:09. Record interval: 1. Symbol: F.US.EPH16 | 2016-01-05 09:02:09
HD Request # 4 | Decompressing data. | 2016-01-05 09:02:09
HD Request # 4 | Receiving Intraday data for F.US.EPH16 starting at 2016-01-05 08:56:09 | 2016-01-05 09:02:09
HD Request # 4 | Timestamp of first Intraday data file record written: 2016-01-05 08:56:09 | 2016-01-05 09:02:09
Socket (10) | Shutdown and closed. | 2016-01-05 09:02:10
The network socket for historical data has been closed. | 2016-01-05 09:02:10
HD Request # 4 | Received 339 records from 2016-01-05 08:56:09 to 2016-01-05 09:02:05 (5.9 minutes) and wrote 339 records for F.US.EPH16 | 2016-01-05 09:02:10
HD Request # 4 | Intraday download COMPLETE for F.US.EPH16. Completion time: 1s. Unique request ID: 3 | 2016-01-05 09:02:10
Removed historical data download ID 3 | 2016-01-05 09:02:10
Real-time Intraday chart data file updates started for F.US.EPH16 | 2016-01-05 09:02:10
It started working around 9:25.Here's the log-thanks Tim
[2016-01-05 15:49:36]
We do not need to see the Message Log.
CQG is currently having a problem with their market data server. We see you are using CQG.
Date Time Of Last Edit: 2016-01-05 15:49:45
