Date/Time: Sun, 19 May 2024 10:32:12 +0000
How do I adjust the following:
View Count: 689
[2015-12-31 05:44:33] |
idcisosf - Posts: 34 |
How do I separate a chart from the file box? How do I change chart minutes? Such as 2 minutes, 3 minutes? How do I adjust chart between ticks spaces? To be big or small? Thanks, |
[2015-12-31 18:10:24] |
1. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html 2. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ChangingPeriodOfBars.php 3. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
