Date/Time: Sun, 19 May 2024 05:43:16 +0000
fatal error LNK1123: failure during conversion to COFF when building with VS 2010
View Count: 1015
[2015-12-30 14:30:47] |
Zosimus - Posts: 345 |
When I try to build a study with VS 2010 I get this error message: fatal error LNK1123: failure during conversion to COFF Will disabling Incremental Linking be a good solution ? |
[2015-12-30 17:38:01] |
We do not know the answer to this question without research and testing.
[2015-12-30 18:36:05] |
ok, so far it seems that disabling Incremental Linking is solving the problem.
