Date/Time: Sun, 19 May 2024 07:45:25 +0000
Problem creating Cum Delta Volume bars as study when Heikin Aishi study on main graph
View Count: 830
[2015-12-30 11:42:31] |
User80541 - Posts: 13 |
I can have Cum Delta volume as a study if i DO NOT have Heikin Aishi applied to my main chart. Works fine. If I do, then the colors are all screwed up and even the bars dont look right Please see attached screenshot. They are duplicate charts, both with Heikin Ashi applied to main graph On the right, I have the Cumulative delta volume showing correctly ONLY because I have made a copy without the Heikin Ashi and have overlayed that study onto what I am showing you On the left, Cum delta looks all whacky since i just added that study on the chart If I remove Heikin Ashi from main graph, then all cum delta volume bars look fine Please help |
CumDeltaIssue.JPG / V - Attached On 2015-12-30 11:41:35 UTC - Size: 305.46 KB - 377 views Attachment Deleted. |
[2015-12-30 18:14:34] |
This issue is already solved. You are running a significantly older version of Sierra Chart. Update following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-30 18:15:00
[2015-12-31 10:22:17] |
Thank you this worked J |
