Date/Time: Sun, 19 May 2024 12:36:23 +0000
Drag the Chart
View Count: 2451
[2015-12-30 03:48:14] |
User78188 - Posts: 10 |
Hi, Is there functionality to click anywhere on the chart and drag to move it? |
[2015-12-30 03:49:43] |
Yes. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-30 17:41:16] |
Is there a way to lock the hand tool so it is always on? When I switch to pointer or cross hair it no longer drags the screen and I have to switch back.
[2015-12-30 18:18:56] |
Indirectly this can be done. You can set the Chart Values tool to be always on and use it with the Hand tool. Refer to the Chart Values Tool Settings here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-30 18:19:14
