Date/Time: Sun, 19 May 2024 08:47:39 +0000
SC.SELLORDER
View Count: 732
[2015-12-30 03:44:41] |
User713273 - Posts: 409 |
Hi- When buying call options the function sc.buyorder is used while referencing column K, but when buying put options referencing column M would sc.buyorder again be used or is sc.sellorder used? These would obviously be for new orders. Can you clarify? Thx |
[2015-12-30 03:51:03] |
You have to use your own judgment on this. We cannot answer this question. Obviously one function buys and one function sells.
