Date/Time: Sun, 19 May 2024 04:55:54 +0000
Vertical Grid
View Count: 1692
[2015-12-29 21:13:31] |
User78188 - Posts: 10 |
How do I change the chart >> Vertical grid setting to plot on specific times? When using a 24h chart I would like it to start on the open and close of the session but it plots from the open and close of the day which is 00:00 - 00:00. I would like the vertical grid to plot from the electronic open to close.
[2015-12-29 21:15:26] |
Refer to the documentation for this setting here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VerticalGridLinesAtEvery Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
