Date/Time: Tue, 28 May 2024 04:31:14 +0000
using code to uncheck the "Display Study Name, Subgraph Names, and Subgraph Values - Globa
View Count: 782
[2015-12-28 11:45:14] |
KhaosTrader - Posts: 128 |
Hi, How do I use code to default the value to unchecked for the setting "using code to uncheck the "Display Study Name, Subgraph Names, and Subgraph Values - Global" I can use code to disable "Display study name" and "Display Input values" but i would like the other one unchecked also. Thank you. |
[2015-12-29 21:13:48] |
See: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scGlobalDisplayStudyNameSubgraphNamesAndValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
