Date/Time: Mon, 20 May 2024 21:28:18 +0000
In need of a specific sierrachart.h
View Count: 747
[2015-12-22 18:06:02] |
KevanCarney - Posts: 2 |
I have a custom study that was developed for us a while back but have lost the source code but I know it was built with version 834 of the API. I was wondering if you have or can find me this particular sierrachart.h header, SC_DLL_VERSION 834. I believe I can get what we need using IDA and having this particular version of the header will help a lot because I'd imagine the s_sc struct has changed since then. Thanks.
[2015-12-22 18:59:56] |
You can install version 834 from this page: https://www.sierrachart.com/index.php?page=doc/SCInstallerList.php With that version, it will have the SierraChart.H file for that version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-22 23:33:43] |
Thanks!
