Date/Time: Sun, 28 Apr 2024 22:12:51 +0000
simultaneous backtest on several independent charts.
View Count: 2115
[2013-03-27 20:44:02] |
sleepless2 - Posts: 4 |
I have a chartbook with 4 charts for 4 different tickers. I have an automated stratgegy that I want to bar based backtest for each symbol. Now I can run the backtest on each chart by clicking on it and starting the backtest in turn. For convenience I want the backtest to run on all the charts as the backtest takes a long time and I would just want to leave it running overnight unatteneded. Note that the charts (and trading systems) are independent. thanks. |
[2013-03-28 21:24:15] |
This is not supported. However, you could easily install 4 copies of Sierra Chart on your computer and run a back test on each one. This way if you have a multicore CPU and most likely you do, each one would run on a separate CPU core. This would be very efficient. To use multiple copies of Sierra Chart please see: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
